The company I work for charges the same rate for licensed and apprentices.
If the customer has a real issue with this the company has changed the rates. The apprentices rate will go down and the licensed guys rate will go up.
If the normal rate is $90 they might make the apprentice $70 and the licensed rate $110.
Either way it ends up being the same money for two guys per hour.
