Thanks Joey, I believe thats the route I'm going to take. How many GFI circuits did you provide, or was it even needed. My understanding is that the animal activist push on this pretty hard. Basically due to the fact that the animals could somehow chew into the wires. I personally don't see it since the wire is protected via the pipe.
Joey how did you bid that job? This barn will have right at 25 stalls. Lights and recpt.at each stall, lights down the ally way, lights and recept. in the tack rooms, and a restroom.
