Leviton recommends 12 in/lbs for screw terminals not otherwise marked.
It isn't terribly tight, just tight enough to hold without squishing the wire.
Now for SQ D Breakers at 35 in/lbs, you'll think you're gonna break it before it's tight enough.
Get a torque-screwdriver, some specs, and play with 'em!
Right, Tom?
