1 members (Scott35), 510 guests, and 14 robots.
#153631 10/24/03 09:48 PM
Ryan_J Offline OP
Are there any limitations on where you may place wall sconces in a commercial building?
Ryan Jackson,
Salt Lake City
#153632 10/24/03 11:55 PM
I don't believe the NEC has any restrictions, but the building code for commercial buildings does have a height requirement, of which I am not sure what the exact height is. It may be somewhere in the 6 foot minimum height range.
Pierre
Pierre Belarge
#153633 10/30/03 07:34 AM
Per the IBC, "Means of Egress"
1003.2.5.3 Horizontal projections
"Structural elements, fixtures or furnishings shall not project horizontally from either side more than 4 inches (102mm) over any walking surface between the heights of 27 (686mm) and 80 inches (2032mm) above the walking surface."
#153634 10/30/03 10:16 AM
Ryan_J Offline OP
Electure:
Well done! I've had to red-tag a few electricians for this. Also, notice how many fire extingiushers don't comply with this.
The intent is protection for the visually impaired. If someone needs a cane to assist their walking, the cane will hit the obstruction if less than 27" AFF. If not, their face may be what hits it. [Linked Image]
Ryan Jackson,
Salt Lake City
#153635 10/31/03 12:00 AM
This is a good example of the type of things we can learn here by getting aquainted with Codes other than the NEC.
[Linked Image] [Linked Image]
