In addition to pwood's post.
The 2 wires, diagonal corners (in addition to the remaining 2 corners being secured to the grid) are a minimum.
This is one place where the CBC can be amended by a municipality, and many do.
Some jurisdictions require 4 corners to be wired, with 4 screws. Some want at least 2 wires, with all 4 corners secured to the grid (usually accomplished w/ tek screws).
I once had a job spec where the architect/engineer (from out of State) must not have been too sure of him/herself.
The plans showed 4 vertical support wires, and 4-45° splayed wires for each fixture!
Another T-Bar rule here is that the grid must be suspended at all 4 corners of the fixture...S
