231
11
Thanks to TrimixLeccy (U.K.) for the following: Let's see if anyone can identify what these tools are for. Probably be an answer within minutes, but I thought they were quite rare and have never seen any others. The 2 tools are both for the same job and the second pic is a close-up of one end of the tool. I am not certain but I am lead to believe that my Grandfather had the tool on the right made some 60 - 70 years ago, family myths and all that. It would be nice to think that he had though ...and yes, they are still used today on rare occasions. I actually used one of them only last week which prompted me to take a picture.
The only thing i can think of is fuse pullers, the left one for glass screw in fuses and the right for cylinder fuses. But thats just a guess.
They are electrical tools right?
Definitely designed to hold something round, but what?
Looks like the one on the left is designed to grab something by tightening the wing nut on the end.
Yep they are Electricians Tools. Being an Electrician runs in the family.
As for being 'fuse pullers'; interesting thought; but about as far away from the correct answer as you could get. Nearly all the fuses in U.K. are enclosed in some form of insulated carrier so a puller is not needed. There was one type of fuse decades ago known as 'A death-wish fuse', where the fuse wire ran along the outside of the carrier. Put the fuse across an uncleared fault and get a striped hand for free!! 0( Even though one of them is wood and metal and the other is all metal they both do exactly the same job. Used the wooden one again today.
Clearly to hold something in place.
The wooden one you squeeze the wood and metal so the jaws open...realease and the spring pulls jaws shut...I could use them to put nuts onto threads in difficult places. Much like a gripping screwdriver for nuts and bolts?
Kenny
der Großvater
Broken bulb pullers, to pull broken bulbs?
Since the wooden/metal tool as shown seems to be completely closed (or nearly so), I don't think it's for gripping anything round. It's more like a pair of pliers for squeezing two things together, round or otherwise. And the wood/metal tool does the squeezing while you push against them.
Sort of like an installation tool for snap-in cord grips.
Ah! It's for grabbing duplex receptacles while twisting them around so they're U-ground-UP! No, wait, wrong side of the Atlantic...
Grabbing shade rings in awkward shaped light fittings?
looks like a crimping tool to me
