#153111 04/25/06 09:32 PM
This is a normal sized single gang cover plate, but with slots for 2 switches? Or maybe it was meant for something like TV antenna jacks?
Anyone know what this cover plate would have gone with?
- wa2ise
#153112 04/25/06 10:25 PM
Probabaly a set of switches mounted vertically on a single yoke.
~~ CELTIC ~~
...-= NJ =-...
#153113 04/26/06 10:12 AM
I saw one of these plates some time back in the front hall of a turn of the century house here. The handles for two tumbler switches extended through the holes - as celtic said, a couple of switches on a single yoke. I did not get to actually see the switches themselves, but imagined they were probably not too much different from the combination devices available today (switch/switch, or switch/receptacle).
#153114 04/26/06 09:49 PM
OMG....it literally JUST dawned on me....I have that plate w/2 switches on one yoke in my own house - I hit it everytime I head on down to the basement...LMAO.
My house was built in 1950, I am the second owner. The first owner made no changes at all - so it is "OEM".
Anyone want pics?
~~ CELTIC ~~
...-= NJ =-...
#153115 04/26/06 10:13 PM
Show em off! [Linked Image]
Cliff
#153116 04/26/06 10:26 PM
Here you go:
Edited to put images on ECN server
[This message has been edited by electure (edited 09-11-2006).]
~~ CELTIC ~~
...-= NJ =-...
#153117 04/26/06 11:06 PM
Oooh, Despard.
#153118 04/27/06 02:34 AM
There's a true value a town over from where I am where you can still buy the switches/receptacles for despard bar units
Cliff
#153119 04/27/06 05:16 AM
There's one question that always strikes me when seeing Despard devices: are there US boxes that can be mounted horizontally instead of the usual vertical orientation?
#153120 04/27/06 07:58 AM
yes and no..
I've never seen a 2x4 box with ears on the short side, but you could always use a 4x4 with a plaster ring in that orientation, or add a block to mount a 2x4 sideways..
my high school theatre had despard low voltage momentary switches all over the catwalk areas, controlling a set of relays for the various worklights/running lights.
