235
27
Posts: 3,682 Likes: 3
Administrator Member
Is this the Romex which has a kind of impegnated cloth sheath? Presumably rubber insulation on the individual conductors too?
The gas range in the background is interesting too. It's the first US range I've seen that looks rather European!
That looks like what I found in the walls at the Girlfriends place, only some HAD bonding conductors and some didn't! The boxes they did bond to ground they just used a nut and bolt arrangement through a hole in the back of the box.. works great until you loosen the bugger then try and re-tighten it!! Lemme guess, they soldered and taped all the connections too eh? Used that " friction tape" stuff that looks like modern day "hockey tape"? A.D
try spending all day working with that stuff with bare hands, it takes a week to get the tar stains off!
You're all on the right track. This stuff does have an impregnated cloth outer wrapper, a kraft-paper liner, and the individual wires are also (probably) rubber insulated, with some more paper wrap. There is no ground wire.
I have not taken this apart as yet; it probably has soldered and friction-taped connections, with no pigtails. If it does I will get some pics.
Also of note is the fire-blocking halfway up the wall. This was common until the late '60's, when it was decided that blocking between floors was enough.
That style of fire blocking makes fishing in walls real fun, it's alright as long as it's a one floor house with an unfinished basment below and attic above, down from the attic for switches, up from the basement for outlets, if you lack one of those and the customer wants something done requiring new wiring, they're most likely not going to be very happy with the new that you're going to have to punch a bunch of holes in their walls. it'd be really cool if you could post up a pic of one of those old soldered/taped connections!
-Will
I see that stuff all the time on remodels. In the 60's I worked in a supply house and we sold it by the reel for Mfgr. homes. When the plastic jacketed wire came out it was sent back because the installers wanted the "regular" wire. The new stuff was too hard to strip. In some installations I have seen where the old cloth covered wire first came out with a ground wire. Electricians didn't know what to do with the ground wire so some would wrap it around the cover screw at a box and at the panel wrap it around the screw on the clamp. Ah, the good old days. Remember the wiring you do today will last the life of the building, or until the fire department shows up. Alan--
Of note, the old "Carpenter's Rule" for blocking = 3 from a corner, and 2 from an opening. These were put in to give the wall rigidity, not as fire stops. (Anyway, that's what my "Old Carpenter" friend tells me)
There's another trivia item in this kitchen, that I forgot to mention- the water heater! That portion of the kitchen counter, to the right of the sink, and behind the fire extinguisher, is actually the water heater. The steel top of the cabinet is formed to make a wountertop, complete with backsplash. All is enamel on steel. (The sink base is of the same type, but the sink / counter above is a replacement for the original one-piece sink/drainboard top.)
[This message has been edited by renosteinke (edited 04-09-2006).]
