#152290 05/13/04 11:05 PM
Found a pair of 6 1/4 amp 120v "Fustat" (Buss) screw in fuses. Not the Edison base type, but using the base designed to keep a user from using a too big fuse.
- wa2ise
#152291 05/14/04 11:08 PM
6¼ amps? was this on a piece of equiptment?
I've come across odd fuse sizes before, but nothing fractional!
-Randy
#152292 05/14/04 11:29 PM
It seems like a odd number, but 6¼A∙120V = 750VA, which is sort of a ‘round’ number. It may have evolved with some UL appliance standard, and not the NEC we’re so familiar with.
#152293 05/16/04 09:13 PM
I have some of those 6 1/4 amp fuses, but with edison bases.
#152294 05/16/04 10:30 PM
I have a 1 6/10 Amp Edison-based plug fuse in my small (but growing - donations accepted gladly [Linked Image] ) fuse collection.
The brand is K-E Thermofuse and is a porcelain plug with a brass/gold colored metal collar that holds the mica window in place.
