1 members (Scott35), 513 guests, and 30 robots.
#152283 05/07/04 06:48 PM
(submitted via Joe Tedesco)
Here is a picture of my youngest son (Caper # 2). He is holding a typical 120 volt 25 watt light bulb in his left hand. In his right hand is a 1000 watt 120 volt mogul base light bulb that my uncle use to use in his photography business. He used it to light his models/subjects while he was on site taking pictures. I thought that you might like a glimpse of this bulb.
Picture one shows David holding the bulbs to give you a size difference between bulbs. Picture 2 shows that actual writing on top of the bulb.
-Harold
#152284 05/13/04 05:49 AM
How much heat did a 1000Watt bulb make? a 200Watt 3Way throws alot of heat. And Is this before the days of HID?
Theres always enough room in the junction box.You just need a bigger hammer
#152285 05/13/04 08:23 AM
That one kilowatt Luxor lamp generates the same amount of heat as a 1000 watt electric heater.
The conversion factor for incandescent lamps to heat is 1:1 (one to one).
Al Hildenbrand
#152286 05/14/04 05:42 PM
My uncle use to be a commercial and model photographer back in the 60's and 70's. He used to have like a big umbrella with the buld on the inside to illuminate the face of the model. There wasn't HID lighting at this time except for fluorecent. (I believe) There use to be some outside light fixtures that would use these same bulbs. Then along came the HID lights and these big bulbs went the way of the T-Rex.
#152287 05/16/04 01:14 PM
Remember the "exploding light bulbs" thread?
That 1k bulb would be a real doozie!
#152288 07/17/04 10:00 AM
One of my first electrical experiences was converting our high school stage lighting equipment from incadescent to halogen bulbs. I learned the hard way about touching the quartz envelope. lol
#152289 07/17/04 10:13 AM
You can still buy 1000 watt mogel base lamps.
[Linked Image from grainger.com]
Lamp,1000,1000 W
Incandescent Lamp, Wattage Rating 1000, Clear, Brass Base, Mogul Base, Lamp Designation 1000, Voltage 130, Lumens 23740, Rated Average Life 1000 Hours, Shape PS52, Maximum Overall Length 9.50 Inches, Diameter 6.50 Inches
This lamp claims 23740 Lumens that is very close to what a 400 watt metal halide lamp produces. [Linked Image]
Bob
