Now, some will say that a 'safety' rule can never be too strict. I disagree. A rule that is not realistic will not only be ignored, but will lessen your respect for all rules. I'd rather not see 'ignore the silly rule' become SOP. Better to have a better rule.
Reno, thank you!! A breath of common sense!! (But see more info below..)
Now if we can kill off those pesky AFCI's......
My new slogan: AFCI's: The airbags of the electrical industry.
Back on topic:
I too am wondering why the disconnect will be open at all times. (And is this referring to the door or the switch blades themselves being open?)
If it's the door, then yes, I feel full PPE will be required anytime anyone is in the arc flash boundary of this disconnect. Remember that if the switch blades are closed, they and any fuses and of course the load lugs are now live.
If the switch blades will be open, i.e. "off" at all times then it could be argued that no, there are no exposed live parts. Thus no real need for PPE.
Finally, 480 volts is nothing to futz around with. Is wearing full PPE a hassle? Probably. How about several days in a burn ward, months in a coma or eternity six feet under? Those are a hassle.
My take: Covered lugs or not, put on the damn PPE!!!**
**EDITED TO ADD THE FOLLOWING POINTS:
With the shields in place, the 'live' parts are well recessed, and cah only be reached with a set of probes- a finger, or piece of falling debris won't make it. IMO, these points are even less exposed than the 'exposed live parts' of any receptacle. Or cord cap.
Very true Reno, and I do agree with the idea that
under these conditions it would be reasonably safe to approach this disconnect without PPE.
BUT, the OP points out that the door would be
left open all the time, presumably even when the disconnect switch blades are closed and energized. So full PPE would be required and not considered overkill.
I had to add this information as it seemed that I was presenting conflicting views in my original post.
[This message has been edited by mxslick (edited 10-08-2006).]
