#150764 11/03/05 05:52 PM
Trumpy Offline OP
What sort of a tool do you guys use to remove blown fuses that you work with?
I mean in particular, the axial cylindrical type fuses.
Your thoughts please?.
#150765 11/03/05 11:52 PM
I believe the one I use is the Ideal 34-002. They work pretty good. One of my journeyman prefers the small 422 channel lock pliers instead.
Tim
#150766 11/04/05 07:09 AM
Trumpy Offline OP
OK,
It's not the actual removal of the fuses that bothers me.
I've seen guys here pull them out with Rubbers and Leather Outers on.
It's inserting the new one that worries me the most.
Is it wrong to not use a tool to remove and replace fuses?.
#150767 11/04/05 12:26 PM
If the power is turned off and secured properly, what is wrong with changing a fuse with your bare hands (providing you don't cut your knuckles in the process?
#150768 11/04/05 04:37 PM
I've had fuses break when pliers are used. Also, it isn't all that unusual for a fuse base to be "hot" even when the disconnect has been opened.
I have a variety of pullers; most are best described as plastic pliers. I find them quite helpful in both removing and inserting fuses.
#150769 11/04/05 06:15 PM
I have an old navy fuse puller that works great on anything from FRNs to the big 200a jobs. It is a fiber/micarta sort of material with big jaws on one end and small ones on the other.
#150770 11/06/05 10:56 AM
George... not this navy, is it?
[Linked Image from oldnavy.com]
I've got an old set like that too... I'll have to check the brand on them.
[This message has been edited by DougW (edited 11-06-2005).]
