In an effort to make the items in this area easier for Members to reference, here is a "Menu" of the Articles and Schematics contained within the Technical Reference Section, along with an included hyperlink for jumping to that topic.
Alternately, set the dropdown box (upper right side under the
"PROFILE"/
"REGISTER"/
"PREFERENCES"/
"FAQS" links) for
"VIEW ALL POSTS" to view all postings here.
Check out
*******To see all Posts in this area******* for more details on this.
Recently Posted Topics:
*Click on the Hyperlink (Underlined "Blue" text) to access that topic*
* New Items As Of October 22nd, 2008:
PSC Motors - SchematicsSimple Designated Circuit Drawings* New Items As Of May 3rd, 2008:
SDS Transformer Grounding DrawingsNew: 4 Wire Delta Transformer Drawings - Open DeltaNew: 4 Wire Delta Transformer Drawings - Closed DeltaNew: 3 Phase 3 Wire Corner Grounded Delta DrawingsNew: 3 Phase 3 Wire Center Tap Grounded Delta DrawingsNew: 3 Phase 3 Wire Ungrounded Delta DrawingsNew: 3 Phase 4 Wire Wye Transformer Drawings* New as of May 13th, 2007:
Pictures of RW and TW Insulated Conductors* New as of January 26th, 2007:
International Color Codes-1st draft* New as of November 27th, 2006:
U.K. - Old IEE Wiring Regs. Issue Dates * New As Of July 15th, 2006:
Touch Control Switch Circuit * New As Of July 5th, 2006:
Time Delay Relay Lamp Puzzle!!! Nice Drawing Lighting A Tunnel * New As Of May 12th, 2005:
Inside A Current Limiting Type Circuit Breaker C84 Annex A - Secondary Grounding Illistrations * New As Of December 19th, 2004:
12 Lead Stator Generators Schematics * New As Of March 7th, 2004:
Basic LAN Map #1 * New As Of January 18th, 2004:
ECN Glossary * New As Of November 22nd, 2003:
Components Listings * New As Of October 30th, 2003:
Conversion Factors and Tables * New As Of September 20th, 2003:
Schematics For: 1Ø Split Phase Resistance Start Motors-Series 1 Schematics For: 1Ø Split Phase Capacitor Start Motors-Series 2 Schematics For: 1Ø PSC Motors-Series 3 Schematics For: 1Ø Split Phase Cap Start/Run, 2 Speed and Shaded Pole Motors-Series 4 Schematics For: Commutator type AC and DC Motors * New As Of September 12th, 2003:
Member Contributed Motor Schematics-1 of 2 Member Contributed Motor Schematics-2 of 2 * New As Of March 8th, 2003:
Corner Grounded 3Ø 3 Wire Delta * New as of January 8th and January 26th, 2003:
3 way and 4 way Switchloops Schematics * New as of December 2nd, 2002:
Basic Planset Symbols-1 * New as of October 18th, 2002:
Transformer Drawings submitted by ECN Member uk systems drawings - images only TVSS + AC filter schematics Grounding Transformers- ZigZags AC Dynamic Lowering Hoist Control Residential Distribution Systems * New as of September 27th, 2002:
Voltage Boost Transformer Schematics-1 Phase Voltage Boost Transformer Schematics-Open Delta Connection Voltage Boost Transformer Schematics-Wye Connection ============================================================
Here are topics posted prior to September 27th, 2002 in this area. Click on the Hyperlink to access that topic:============================================================
Panel Schedules Schematics reposted from Theory Section Buck/Boost/Choke + Polarity Test Schematics 1 phase transformer drawings - part 1 1 phase transformer drawings - part 2 2 phase transformer schematics 3 phase delta transformer schematics 3 phase wye transformer schematics 6 and 9 phase transformer schematics simple AC filters simple 5 wire DC systems IG details #1 Locomotive Prime Mover Shots Locomotive Traction Motor Shots Trackside Signal Eq. 1 Simple 3 wire DC circuits UK power systems #1 thru #4 Simple Electrical Formulas #1 Simple Circuit Calcs #1 Basic Circuits #1 - Series Basic Circuits #2 - Parallel Basic Circuits #3 - Series-Parallel and Volt Dividers Series AC circuits - basic Parallel AC circuits - basic Series-Parallel AC circuits - basic AC Motor Control Balanced Power Schematic GFI Wiring Schematic AC Incandescent Lamp Dimmers 1 phase motor drawings #1 3 phase Wye motor drawings 3 phase Delta motor drawings 2 phase motor drawings A little humor Inverter Schematics Full Wave Rectifier - 3 phase input 1 phase rectifier schematics Dynamic Braking for Induction Motors Forward / Reverse 3 phase motor control Start / Stop 3 wire control Panel Schedule - Test Post HID Ballasts: CWA HID Ballasts: CW 1 and 2 Lamp HID Ballasts: CW / REG-LAG HID Ballasts: High Reactance type HID Ballasts: Reactor Type Instant Start Ballasts Lead/Lag Ballasts Preheat Ballasts Series Sequence Ballasts F40T12 Lamp Ballast 2 way 1st and 2nd order crossovers 2 way 3rd order crossovers 2 way 4th order crossovers 3 way 1st order crossover 3 way 2nd order crossover 3 way 3rd order crossover 3 way 4th order crossover 2 way 4th order crossover w/ L pad 3 way crossover - 4th order W/ Z eq. =============================================================
< END >
Hope this list is useful.
Scott S.E.T.
P.S. If you have anything to contribute here, contact me via the "E-Mail" link on any page;
- Or -
contact the Webmaster at:
[email]webmaster@electrical-contractor,net[/email]
TIA!!!
* Hyperlinks repairing (work in progress),
* Add Two new linked items.
