1 members (CoolWill),
250
13
Posts: 3,682 Likes: 3
Administrator Member
CPSC, Marshall Gas Controls Announce Recall of LP-Gas Regulators Used on Gas Grills WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission announces the following recall in voluntary cooperation with the firm below. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of product: Marshall Gas Controls Model 451 and 452 LP-Gas regulators on Char-Broil®, Kenmore®, and Thermos® brand LP-Gas Grills shipped to retailers between April 15, 2003 and May 6, 2003.
Units: 35,000
Distributor: Marshall Gas Controls, a division of S.H. Leggitt Company of San Marcos, Texas
Hazard: Some of these regulators were assembled with an undersized seat disc that could become dislodged and leak propane gas. Propane gas is highly flammable and could ignite causing a fire or explosion. Consumers should immediately close the valve on the service cylinder if LP-Gas leakage is detected.
Incidents/Injuries: None reported.
Description: These low-pressure regulators control petroleum gas pressure in gas grills. The regulators are used with Char-Broil®, Kenmore® and Thermos® brand gas grills. There are two model gas regulators involved in the recall. Model 451 is a single outlet regulator used on grills with traditional burners in the main box. Model 452 is a dual outlet regulator used on grills with a side burner adjacent to the main box. The regulators have date codes printed on the valve body. Date codes included in the recall are 13-03/03-13, 14-03/03-14, 15-03/03-15, 16-03/03-16, 17-03/03-17 and 18-03/03-18. Click >> Recall, Photos
