216
11
Posts: 3,682 Likes: 3
Administrator Member
CPSC, Vaxcel International Co. Ltd. Announce Recall of Ceiling Fan WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission announces the following recall in voluntary cooperation with the firm below. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of product: Ceiling Fans
Units: 1,200
Distributor: Vaxcel International Co. Ltd., of Glendale Heights, Ill.
Hazard: About 80 of these units were improperly assembled with a metal sleeve that could cause exposed wiring. If this occurs, consumers are at an increased risk of receiving an electrical shock during installation or removal.
Incidents/Injuries: None reported.
Description: These dual-motor, 36-inch ceiling fan were sold in chrome, stone white, brush nickel, polished brass, antique brass, or weathered patina finishes. Model number 355-6645 is printed on a label located on the central housing of the ceiling fan. The brand name of the fan, "Aire Tek" is written on the packaging only.
Sold at: Independent retail lighting stores nationwide between January 2002 and May 2002 for between $350 and $450.
Manufactured in: Taiwan.
Remedy: Consumers should contact Vaxcel to determine if their unit is defective. A free, replacement ceiling fan will be provided to consumers with defective units. To avoid the risk of shock while removing a recalled fan, consumers are encouraged to use a professional electrician. Vaxcel will reimburse consumers up to $75 for charges incurred in removing recalled fans.
Consumer Contact: Call Vaxcel at (800) 482-9235 between 9 a.m. and 5 p.m. CT Monday through Friday. Click >> Recall Notice
