Well, since OSHA Professor decided to point out my posts, I figured it only fair to register and post a response myself to this discussion.
First, I have to agree that some of the prices were a little on the high side for the safety equipment mentioned sparky66wv, but I am also sensitive to the fact that some of youare just trying to make a living, and this is additional cost to you. I'll back up OP by repeating that any of you can call HFS and mention that OSHA Professor or Andy Shockmore gave you the number and you'll get the best treatment available. EVen if you've found a lower price, they'll beat it if possible.
But this is really what you have to consider....how much is your life...or even the QUALITY of your life...worth? I'm sure the electrician here locally who decided to install a circuit breaker in a live panel in Sears is wondering that. He was burned over 60% of his body. There are some things to consider about all of this. Why are you working live? This safety equipment is only needed for LIVE work. If you insist on working live (for whatever reason) and you do wear/use the gear described in this thread, are you aware that it is designed to reduce the injuries sustained (when used properly) to a "curable burn"? A "curable burn" is 2nd degree burns.
To once again back up what OSHA Professor said, the typical electrician should have as a minimum:
FR Uniform OR FR coveralls (for live work).
Face Shield (for live work)
Class 0 or 00 gloves with leather protectors, glove bag and dust (for live work)
Safety Shoes with an EH (Electrical Hazard) rating on the sole
insulated flat/phillips screwdrivers (for live work)
If you need more than this you really need to reconsider the work you do live or you are probably performing specialized tasks.
