0 members (), 331 guests, and 10 robots.
A member advised me of this information and it appears questionable. Look it over and please add you comments.
http://www.blackanddecker.com/ProjectCenter/workshoptips.asp?DOC_ID=p_3_27_15138_15139_15140.html
do U mean the use of LOTO Joe??
[Linked Image from blackanddecker.com]
[This message has been edited by sparky (edited 11-10-2002).]
Soap?
Remove a broken light bulb—after turning off the electricity or unplugging the lamp—by inserting a bar of soap, then turning counterclockwise. Discard the soap. Or, use needlenose pliers to grip the filament or the metal base of the bulb.
[This message has been edited by Joe Tedesco (edited 11-10-2002).]
yeah...uhm...soap?.... thought that sort of odd too....a twist on the old irish spring commercials came to mind..... [Linked Image]
I've never seen soap recommended for that purpose before. Usually they call for a potato... [Linked Image]
The tip of a pair of needlenose pliers, spread open against the inside of the screw shell, has always worked for me...even on large lamps or ones with a bayonet base (like some stage lighting lamps).
I've never been one to waste a perfectly good potato... [Linked Image]
Looking at that ampacity table, I would think that an 18awg. extension cord for any kind of power tool would be pretty flimsy.
[This message has been edited by mamills (edited 11-14-2002).]
OK—that begs the obvious question: what would you rather do after you replaced the lamp? Use the soap bar on your armpits—or eat the potato?
Ya gotta give em credit for that much consideration of a LOTO.
TW
