WASHINGTON, D.C. - In cooperation with the U.S. Consumer Product Safety Commission (CPSC), Greenlee Textron, Inc. (Greenlee), of Rockford, Ill., is voluntarily recalling about 650 electrical testing meters. The meters are used to measure voltage and current of electric-powered equipment. An incompatible grommet, located in the battery compartment to protect internal wires, can cause the meter to provide inaccurate voltage and current readings. A meter that inaccurately indicates zero voltage or current creates the potential for electric shock or an electrocution hazard from the equipment being tested.
CPSC and Greenlee have not received any reports of injuries or property damage. This recall is being conducted to prevent the possibility of injuries.
Click >>
more info
