Electricians revenge
0 members (), 205 guests, and 12 robots.
Ground Faults that caused accidents:
http://www.osha.gov
[This message has been edited by Joe Tedesco (edited 03-21-2001).]
A lot of cord connected scenario's here, note # 126052380...the one where the water dept. gets a tickle undooing the underground h2o line...
This could happen under a code compliant situation
Anonymous
Unregistered
http://www.osha.gov/cgi-bin/inv/inv1xp?s=170165856027 :
"A temporary power pole equipped with a ground-fault circuit interrupter supplied the trailer, and this was found to be wired correctly by city building inspectors. (the original report did not state why the ground-fault interrupter did not trip.)"
But it was probably because it was wired wrong!
Dspark,
There has been a sort of survey conducted recently that reports a very large percentage of non-working GFCIs are in the field. It is suggested that many are damaged by exposure to weather and power surges. This may be one that falls into that category.
I once came across a pool light (120v) with a broken lens (water in the fixture) that did not trip a properly wired GFCI receptacle. The GFCI cover was damaged or missing and I think that the contacts must've been rusted in place.
Anonymous
Unregistered
I have yet to see a non-working GFCI for any reason other than reversed line and load.
But that is because there are so few of them anyway.
I know that even I don't test my GFCIs monthly. In fact I just recently got my sons to test them all upstairs. I think I have one in the basement that hasn't been tested for a year and a half.
Perhaps so. Silly me, when I read that report I thought it said that it was wired incorrectly.
