The result has been that we're getting very close to the max generation capacity of the existing plants. Because of the huge demand maintenence cycles can't be followed as normal i.e. plants can't have their usual down time.
Exactly
djk, You hit the nail on the head!
It's that bad at the moment that simple maintenance becomes impossible, These last two outages were due to line maintenance only. By having a second circuit off for busbar work and installing new insulators and new line breakers a little shift in loading causes overload and tripping.
The attitude towards the thermal stations is, 'We just run them harder' , which means in general they clock up more running hours, more wear and tear and eventual faillure of plant.
In New Zealand we rely for about 70% on hydro capacity, a fair amount (± 1200 MW)comes from the South Island via the interconnecting DC link across the Cook Street.
North Island has around 1600 MW hydro available from various stations all over the place.
Thermal stations (± 3000 MW)are there for back up and some are used for base load in the North Island.
Some are
peak load stations which were designed for periods up to 4 hours at a time morning and evening peak periods.
Sometimes these stations run for days at a time when the hydro lakes are low.
You can see that is receipt for disaster.
And also what you mentioned too
djkWe have no access to an other bulk grid supply. Nearest would be Australia which is about 1700 kms away.
I will keep you posted from power hungry Auckland.
Cheers Ray
Edited for insert of text I forgot
[This message has been edited by RODALCO (edited 04-22-2006).]
