that chassis layout has been around since the 50's. In fact I'm trying hard to think of any set, valve or solid state that doesn't have the EHT bits on the right rear corner.
Hmmm..... You've got me thinking now. I'll have to dig out some old service sheets tonight see if I can come up with anything.
Murphy was a British manufacturer noted for often coming up with "odd" ways of doing things, so those sets might be worth a look.
The controls down the right-hand side convention may well have contributed to the layout. For example, once varicap tuning came along the channel selector could have been placed almost anywhere in relation to the actual tuner, but before then the tuner was normally fitted right behind the controls, for obvious reasons. With the tuner(s) on the left, as viewed from behind, it would then make sense for the I.F. stages to be close by, and so on, down the chain.
like the Sony seperate EHT and line output stages of the 70's.
Again, I'm pretty sure some of the earlier Murphy sets (possibly others too) did this in the early 50s. The EHT in some of those could be quite lethal -- Literally.
who remembers Sony with their unique PAL decoder to avoid paying royalties to Telefunken? Instead of reversing the R-Y every second line, it stored and released the R-Y from the previous non inverting line instead. It could be said that the colour definition was therefore effectively halved. Also, a manual phase or hue adjustment was required like NTSC sets.
I don't remember that one. What sort of time period was this?
By the time you add the delay line to store the non-inverted R-Y, it seems you might just as well have gone with a conventional PAL decoder, but I suppose it depended how much they would have been saving in fees.
I don't know about Australian models as color didn't arrive there until later, but some of the earlier color receivers in Britain were the PAL-S type. They had the R-Y inversion synched to the swinging color burst as usual, but no delay line, so they just relied on a visual averaging between lines to cancel out any phase errors.
