0 members (), 560 guests, and 20 robots.
#143607 08/08/05 04:14 AM
C-H Offline OP
Just took my sunglasses off after my recent trip [Linked Image] I won't tell you the country, though.
(A little challenge there...)
I took a lot of photos, some of them "electrical". I had bought a $100 digital camera which worked very well apart from the fact that it wouldn't work in anything but very good light. Most electrical photos were simply too bad to be useful. Oh, well, what did I expect? [Linked Image]
Here is a panel with electrical meter in a private home. Diazed fuses, with what appeared to be 16A fuses throughout. The wires are 1.5 mm2, mainly in NYM style cable or orange flexible conduit (16 or 20 mm dia). Color code in all installations appear to be the "old" European. (Blue, Black, Brown, Black) This was the only panel I found without an RCD. All others, even old ones, had an 500 mA RCD.
Pic
Here is a supply entry cabinet. (I honestly don't know what to call it) The supply cable comes in from the bottom. Found in the outside of building walls.
Pic
I opened a cabinet in a larger installation to see what was inside: Fuses and a meter
Pic
Below are three pictures of the distribution wiring.
Pic
Pic
Pic
Almost all OH wiring is cabled, but retains the insulators as connectors. Looks funny.
Here is an unusual tap, and two poor pictures of it:
Pic
Pic
The cable comes off the service wires to a home and enters the street lighting through a hole cut in the lamp. The lamp works, though.
Next is a warning sign, found on a transformer station.
Pic
This type of switch plate was found outside the bathrooms of private homes. Identical, but the order of the switches was random, though.
Pic
[This message has been edited by C-H (edited 08-08-2005).]
#143608 08/08/05 09:23 AM
Well C-H,
Fine pics you have there!.
I can't say that I can even throw a wild guess at where these pics where taken. [Linked Image]
Would I be close by saying Poland?.
I would loosely call it an Intake Box.
In pic #4, I can't help but think that that is a UHF TV Aerial attached to that streetlamp to the right of the picture?.
In the bottom pic, what is the switch on the left for?.
[This message has been edited by Trumpy (edited 08-08-2005).]
#143609 08/08/05 09:35 AM
C-H Offline OP
Not Poland, but you are in Eastern Europe... [Linked Image]
The switches in the bottom pic are:
Hot water cylinder - Light - Space heater
The heater looks just on the switch: Simply a bare element with a reflector behind it. About 1000W. (Dang! I didn't think of taking a pic of it.) The nameplate had a manufacturing date of 1986 stamped on it.
#143610 08/08/05 05:16 PM
I'm thinking either Hungary or Czechkoslovakia (yeah, I know it's two separate countries now [Linked Image] ).
#143611 08/08/05 05:30 PM
Further south? Croatia?
#143612 08/08/05 08:59 PM
I often wonder when I see mains distribution along walls of old buildings like that...how rampant are unauthorised (unmetered) tap offs?
Sometimes in areas like this it looks like you can just reach out a convenient window and help yourself to whatever phase takes your fancy! And as for taking your domestic supply from the nearest streetlamp...well it looks like no one would even care, let alone notice.
#143613 08/09/05 03:28 AM
I think the real question to ask is, how far will C-H travel for a vacation?
Claus, did it involve a plane ride?. [Linked Image]
#143614 08/09/05 04:51 AM
C-H Offline OP
Yup, plane and bus. Alan is almost on it... One step south / southeast...
#143615 08/09/05 05:05 AM
I suppose Yugoslavia.
[This message has been edited by Gloria (edited 08-09-2005).]
The world is full of beauty if the heart is full of love
#143616 08/09/05 05:58 AM
C-H Offline OP
Right on! Serbia-Montenegro.
