552
33
How do you post a pic on your topics, or on a thread to make an explanation? do you have to use html? which would mean I need a hosting service , right? Thanks.
I did not get as think so badly as you shocked I did.
Posts: 2,236 Likes: 1
ECN uses UBB for the most part, and yes, you would need hosting, and free hosting like Geociteis tends to cause problems. The other option is to send your pix and a desciption to: photos@electrical-contractor.netOK, I've got to get out into the field now!
I'm told this hosting service doesn't cripple the images from linking: Picturestage.com Haven't tried it yet... My ISP limits me to 5 MB and this one gives 50MB for free!
cool, Im almost done with Mike Holt online illustrated changes for 2002 NEC test.Its taken me 5 hours to through all the articles. Its doing me some good , I hope. I have the sbcci test tomorrow am. Im gonna try that host [This message has been edited by Sean WB (edited 09-20-2002).]
Good Luck Sean! I've got a gig with Fat Headed Monster tonight, so I won't be logging back on until about 0400 EDT, and then for only a very short while! Even if you don't pass, you'll have a better idea of what is on the test for the next time... But I have a feeling you'll do fine! You're already a far cry from most Masters in WV that I've come across- Tom being one of the exceptions. Go get 'em killer! [This message has been edited by sparky66wv (edited 09-20-2002).]
Posts: 440 Likes: 3
Thought I would try Picture Stage. Here is the result. Check out my media collection on PictureStage! To get there, go to www.PictureStage.com and log in as a Guest using the following information: Log-in ID: thewattdoctor Guest Password: doc's [img] http://home2.picturestage.com/servl...568&goNext=/photosharing/albumindex. html?[/img] Trying it out, Doc [This message has been edited by The Watt Doctor (edited 09-20-2002).] [This message has been edited by The Watt Doctor (edited 09-20-2002).]
The Watt Doctor Altura Cogen Channelview, TX
test
ok, i got a pic uploaded to the thread, why is it so small?? well, I had one [This message has been edited by Sean WB (edited 09-21-2002).]
