373
12
I came across this animal in none other that Southern California USA, wired into a 30A 240V clothes dryer receptacle with a piece of extension cord... It bears no legible markings & is obviously not domestic from here... Thanks -Randy
It looks very mutch like a what used to be termed as a D& S socket(sorry, receptacle) must confess though I never saw one in twin configuration. If it is D&S im going back to the late 1960's. Then it was a very early attempt at a fused outlet. One of the pins in the plug top was fused as I remember. Unless anyone knows different that is.
Aland, sorry to correct you, that's a simple surface-mount double Schuko socket like every hardware store in Austria and Germany sells. Rating 250V 10A DC/16A AC (though no one ever used that for DC). I've had one of those in my room for ages until I renovated and put in a flush mount one. 30A and an extension cord is pretty hefty though.
I take it that the central hole (black spot) is a fastener. What would be the grey spots, positioned centrally towards the middle, of the adaptor? Are these where French ground/earth pins could emerge?
Looks to me that the gray screws hold the cover on the base, and the black holes between the contacts are where the ground strap is bonded to the cover.
could you make a pic of the opened device, perhaps you can see a manufacter anywhere.
Yes, I've got one here that looks exactly the same. The black things are the rivets that hold the ground scrapers and the grey screws hold the cover. Hutch: It's not an adaptor, it's a real duplex receptacle! I'll post pics of mine as soon as I got my imaging software up again. Mine is mady by Kopp, you can read the brand name on the back side of the bottom part of the receptacle, between the mounting holes. There's also VDE and ÖVE listing and the 10-16/250 rating.
Posts: 1,498 Likes: 1
Randy, you find the strangest things! Here is the matching plug for it: As you can see, it is a grounded two pin plug [This message has been edited by C-H (edited 05-31-2004).]
Strange that such a device should turn up in California, but then I once bought a big box full of U.S. wiring devices (mostly Hubbell) at a local junk shop. I reckon it may have been surplus from one of the North Sea oil rigs, some of which apparently are wired to American standards. Got the box real cheap: Nobody else wanted it......
The centre spot fooled me initially it looks like a third pin hence my thoughts about it being a D & S outlet these did have a centre pin. I am getting to old to see all this fine detail.
