216
8
At a flea markte I bought a book about video that dates 1982. The appendix shows a table of worldwide TV systems, voltages and frequencies. Some entries were that weird I wanted to share them - just for fun. It is sorted by TV systmes. NTSC: USA System M channels A2-13, A14-83 120, 230, 240V 60Hz b/w: USA
PAL: UK I 21-68 240/415V 60 (!) Hz, UK Hongkong I E21-60 200/220/346V 50 Hz Ireland (ROI) I A-J, 29-43 220/380V 50Hz, Belgian Luxembourg C, G E 7, 27 110/220V (???) 50 Hz Belgian NZ B NZ 1-10 230/240/415V, 50Hz CCIR Norway: 230V only. No 3ph??? South Africa I I4-13, 21-68 220/230/380V 50 Hz, UK
SECAM: Cyprus B (H) E 5-11 115/400V 50 Hz CCIR Luxembourg L(V) 21 380V 50 Hz Belgian Sowjet Union D, K(V) R1-12, 21-69 127/220/380V 50Hz OIRT
All other Eastern block countries aren't even mentioned. GDR had SECAM, some others supposedly as well, others PAL. There are still some videos around that have a sticker: SECAM (GDR) reception!
Well, you could have 60Hz here if you care to run your own generator or converter-set. But then if you do that, you could have anything, anywhere! These tables are notoriously unreliable, but this one looks worse than most. Apparently Luxembourg has 110/220V service available for system-C receivers, but you can only run system-L sets on 3-phase! (Seems more likely that Luxembourg was a mix of 127/220 and 220/380 systems 20 yeas ago.) I wonder why "Belgian" is tacked on the end of several entries?
The Irish listing is almost correct although I have no idea why you would want to use a 380V 3-phase television!
Correct info:
220/380V 50Hz
TV System: 625 line PAL I (with teletext & nicam digital stereo) Channel Scheme : Irish Licenced channels: Band 1 (Low VHF) Channels A, B, C (No longer used for broadcast TV but still in use on cable) Band 2 (Used on cable only) Band 3 (High VHF) Channels D, E, F, G, H, I, J (J is no longer used for TV)
UHF Channels 21 - 69
Actual VHF Frequencies: Band I Vision Sound (Mhz) A (2) 45.75 51.75 B (3) 53.75 59.75 C (4) 61.75 67.75 Band III Vision Sound (Mhz) D (5) 175.25 181.25 E (6) 183.25 189.25 F (7) 191.25 197.25 G (8) 199.25 205.25 H (9) 207.25 203.25 I (10) 215.25 221.25 J (11) 223.25 229.25
MDS Frequencies: Vision / Sound (Mhz) (Now used to carry digital multiplexes) m1 2501.25 / 2507.25 m2 2509.25 / 2515.25 m3 2517.25 / 2523.25 m4 2525.25 / 2531.25 m5 2533.25 2539.25 m6 2541.25 2547.25 m7 2549.25 2555.25 m8 2557.25 2563.25 m9 2565.25 2571.25 m10 2573.25 2579.25 m11 2581.25 2587.25 m12 2589.25 2595.25 m13 2597.25 2603.25 m14 2605.25 2611.25 m15 2613.25 2619.25 m16 2621.25 2627.25 m17 2629.25 2635.25 m18 2637.25 2643.25 m19 2645.25 2651.25 m20 2653.25 2659.25 m21 2661.25 2667.25 m22 2669.25 2675.25
Guess so, I had a real good laugh. The last entry (UK, CCIR, Belgian) refers to the method of black-and-white transmission. 127/220/380V (i.e. 127V 3ph w/o neutral, 220/380 3ph) was usually listed seperately, but maybe they mixed it up for Luxembourg. Every country has the 3ph voltage listed if commonly available. The header said you could have your video equipment converted to work on any system and this was supposed to give you+ TV technician information to do the conversion. Whatever. poor guys if anyone actually tried that.
No idea. Just copied it from the book. They say the differences are negligible in most cases. BTW I'd really love to see the 380V TV set from Luxembourg!
I've seen the odd tourist take that sort of advice WAY too seriously and arrive in Ireland with big bag of utterly useless adaptors.
DJK's link looks a fairly comprehensive reference, and certainly better than most! Have a look here for a short article on the closure of the old British 405-line system: http://www.meldrum.co.uk/mhp/features/405death.html
"I wonder why "Belgian" is tacked on the end of several entries? " Yes, I wonder why !? Sorry for tacking this thred too, Paul!
Posts: 147 Likes: 3
All other Eastern block countries aren't even mentioned. GDR had SECAM, some others supposedly as well, others PAL. There are still some videos around that have a sticker: SECAM (GDR) reception! I see this are a late answer, but: Noray has 2 systems running, Old 230 delta IT 3 phase or single phase. Newer 230/400 single/3-phase as the rest of Europe. dsk
CDS
Nicholson Ga
