Argile,
Quote from you.
You are all sadly mistaken if you believe that for one ohm's law applies to AC as well as DC.
Please check out the following link. I will admit that I have not checked out the entire site, but it does appear as if it is from NASA. If you think you are smarter than NASA then I think you should start desiging rockets.
http://www.grc.nasa.gov/WWW/K-12/Sample_Projects/Ohms_Law/ohmslaw.html As for the rest of your comments you appear to be all over the place. Yes it is the current that kills you, not the voltage. Current is kinetic energy and voltage is potential energy.
Now please stop pissing off the people on this fine board. I enjoy it too much for someone to come in and start spouting off irrational stuff.
Scott
