by ale348 - 03/29/24 01:09 AM
by NORCAL - 03/19/24 05:11 PM
#140218 02/10/04 03:20 PM
Guys,
I am looking for good grade pyro tools, especially a fast, durable stripper. Can you help?
regards
lyle dunn
#140219 02/10/04 07:14 PM
When ‘pyro’ is brought up, I immediately think of exothermic welds, often installed for subsurface grounding connections. They are always bare, so no stripper is used.
http://www.thermoweld.com/products.html http://www.erico.com/products/Cadweld.asp
Understood that ‘pyro’ could have a different/regional meaning.
#140220 02/11/04 12:53 AM
Bjarney,
Pyro is short for Pyrotenax,
it is a brand of Mineral-Insulated, Metal-Sheathed (MIMS) cable. [Linked Image]
Lyle,
Have you tried the site of Radio Spares Components? (RS Components) as they used to sell tools for Pyro work.
#140221 02/11/04 01:04 AM
Lyle,
I asume that you are looking for a tool like this:
At http://www.radionics.ie there is a tool like this listed as Cat No. 369-264 and it has the Code ZSJ.
Hope that this is of some help to you!. [Linked Image]
[This message has been edited by Trumpy (edited 02-11-2004).]
#140222 02/11/04 10:03 PM
Mike — That's a very interesting looking tool. Where does it vent the requisite smoke and flames? ;-) ;-) ;-)
#140223 02/12/04 04:43 AM
Bjarney,
MIMS cable is invariably made from a Copper Sheath with a Chalk inner holding 2 or more wires in suspension.
The wires themselves, having a 200 degree C+ rating.
They are used in the Non-US Areas for providing circuits in Boiler-Rooms and other High Temperature areas.
Biggest thing that anyone that works with MIMS, will tell you, is moisture!.
Allow a wee bit of moisture into a MIMS cable and see the Insulation Resistance to drop like a stone!. [Linked Image]
