#140039 01/15/04 11:20 PM
Hutch Offline OP
This is probably one for Paul but if anyone else knows that will be fine.
I am needing to make up a phone patch cord from a US (RJ11?) phone cable but with a British Telecom plug on the other end (computer modem conectivity). I seem to recall that the UK uses the outer two pins for line 1 as opposed to the centre two. I am not certain about the polarity though on a UK telephone connector.
I see that unlike 8 pin cat 5 computer plugs, each end of a telephone lead is wired as a mirror image of the other.
Thanks - just about to reach for my UK raincoat!
#140040 01/16/04 08:45 AM
Yes, the line is on the outer pair of contacts.
If you place a BT431 plug with the contacts uppermost and the latch on the right, then the A-wire (tip) is on the left and the B-wire (ring) on the right. These correspond to terminals 5 and 2 respectively on a BT socket. Pin 3 is used for ringing and is connected to pin 2 via a 1.8uF capacitor in the master jack, so if you're using a 4-wire cord make sure the other end doesn't connect to anything which will be affected by this.
By the way, thanks to a major lack of communication, when these plugs were introduced in 1981 we ended up with the official standard numbering the pins on the plug the opposite way around to the terminals on the socket! [Linked Image]
#140041 01/16/04 11:15 AM
Hutch Offline OP
Paul,
Do you have any idea which is the 'A' and 'B' wire on the RJ11 plug. I feel like I have a 50:50 chance on correct polarity.
Hutch
#140042 01/16/04 11:25 AM
djk Offline
According to eircom's technical requirements they're not necessarily polarised in Ireland and it shouldn't matter to a normal phone which way they're connected. Particularly as balanced ringing is in use.. i.e. 40V out of phase on both legs.. i.e. you get 80 ish volts between the two.
However, that being said, almost all phone wiring is correctly polarised.
Green: Tip line 1
Red: Ring line 1
Black: Tip line 2
Yellow: Ring line 2
Turn an RJ 11 plug upside down and look to see normal polarisation of the centre two.. should be green & red.
they're always the centre pair though.
[This message has been edited by djk (edited 01-16-2004).]
#140043 01/17/04 09:29 AM
If you place a 6-way modular plug with its contacts up and the locking tab underneath, cord coming toward you, then the contacts are numbered from 1 on the left to 6 on the right. 4-way plugs have only 2 thru 5, of course.
Standard connections are then:
Pair #1: Tip=4 (green), ring=3 (red)
Pair #2: Tip=2 (black), ring=5 (yellow)
As Dave said though, most modern equipment isn't at all fussy about polarity.
Ringing on the common System X exchanges here isn't balanced. Normal idle conditions have -50V battery on the ring/B-wire, but on an incoming call battery is transferred to the tip/A-wire and AC ringing voltage is applied to the ring/B-wire.
#140044 01/17/04 12:17 PM
Hutch Offline OP
Thanks Guys. The lead is made up. I'll let you know if it works next week when I plug the laptop into a London phone jack - if it works of course! [Linked Image]
#140045 01/17/04 02:04 PM
Hope you have a good trip to the Big Smoke!
If it's a modern-ish American modem and the outer British pair connect to the inner U.S. pair then it should work whichever way round it's wired.
I'm sure you realize that strictly speaking it's illegal to connect anything to the lines which doesn't have BABT approval....... [Linked Image]
(Paul exits quickly, muttering something about having to edit out references to American 500-type phones in his house. [Linked Image])
#140046 01/17/04 09:37 PM
djk Offline
Is BABT approval still strictly enforced?
I would have thought that TBR21 (european harmonisation) requirements would have been all that's required these days.
Btw, according to a France Télécom document I was reading TBR21 requirements include a reference to the use of standard RJ11 connectors on the phone/modem/fax end and are supposed to make it illegal to use non-standard wiring i.e. the phones should be wired to carry the line on the middle pair... the BT way's not acceptable [Linked Image]
#140047 01/18/04 08:30 AM
You may be right. To be honest, the rules and directives pouring forth in recent years are so numerous that I've given up trying to keep track of them. Most new telephone equipment sold here now comes with the CE 0168 mark on it.
BABT approval was never strictly enforced from a practical point of view. When the system was introduced in the early 1980s the requirement was that approved equipment must carry a sticker with a green dot and the appropriate "approved for connection" wording.
It was still perfectly legal to sell unapproved equipment; the only requirement was a sticker with a red triangle stating "Prohibited from connection..." (It could legitimately be used on a private system, for example.)
I certainly used all manner of home-built and imported Hayes modems back then which were illegal to connect to the PSTN. Nobody ever bothered me.
#140048 01/18/04 06:33 PM
djk Offline
I was also reading that's there's a european standardisation of tones to 425Hz...(most of our exchanges produce dial tones/busy tones etc at 425Hz).. the odd one will still use 440Hz though..
The british and irish ring tone is way off the EU standard .. I much prefer it though.. instantly recognisable as ringing.
