djk Offline OP
Just look at these:
http://www.yuanky.com/p39-ya-swit-7316.htm
Note the creative use of a single ungrounded 2.5A Europlug to supply multiple BS1363 and/or BS546, NEMA and other outlets via an extension reel
Rather scary looking!
[This message has been edited by djk (edited 01-04-2004).]
Eastern Europe, perhaps?
Maybe countries in Asia, Middle East, Africa. I wouldn't be surprised that they're even for sale in PRC, Hong Kong and Taiwan (even though Taiwan uses American style plugs).
If the wire gague is made big enough, wouldn't a Europlug be able to handle that amp load? Considering how under-rated and over-designed a lot of British and European plugs seem to be...
I noticed a certain plug design that they're featuring has been ripped off from an American manufacturer (or should I say marketer. The actual plugs are now made in Cooper's factory somewhere in Mexico [Linked Image] ).....
[This message has been edited by SvenNYC (edited 01-04-2004).]
C-H Offline
The test current of the Europlug is 10A if I remember correctly. But you loose the earth on the BS 1363 socket!
djk Offline OP
http://www.yuanky.com/p14-ya-swit-732.htm
Notice item 825
COMPLETE ripoff of MK's patented shuttering system.
C-H Offline
Funny company. The homepage/catalogue is rather confusing. I sure hope the actual products aren't made to the specifications mentioned. (13A socket rated 10A???)
Those British circuit breakers looks rather American to me:
http://www.yuanky.com/cb-m3-60.htm
Talking of ripoff: YYL (MODEL HAGER C)RCD
http://www.yuanky.com/cb-yyl-rcd.htm
I bet a few just "happen" to be marked with "Hager" when they come off the line! [Linked Image] What other reason would there be to have twenty different styles of RCD's?
C-H Offline
Their American range looks better.
http://www.yuanky.com/yy-cb-GFC1.htm
But what does "Protection of mis-grounding of neutral line: less than 2MHz" mean?
Are double switches in a receptacle cover common in the US? (The switch to the right in the left picture)
Well...this is the knock-off Yuanky-brand plug I was talking about:
[Linked Image from yuanky.com]
And this is Cooper Wiring Devices' "original"
[img]http://images.lowes.com/product/032664/032664325809.jpg?wid=158&cvt=jpeg[/img]
There's also a two-pin version.
Hmmm.....unless Cooper licenced the design to them also? Probably not.
Are those Cooper-manufactured plugs the old Leviton design? I have a couple of Leviton armored caps that look exactly like the one pictured.
I'd have to check, but I believe the Leviton fittings have the screws flat against the plug face. I know the Cooper ones are vertical to the face (Cooper uses the same face for their metal clad, rubber, and lexan plugs, and I have plenty of the last two around, as I almost exclusively use Cooper fittings)
There may be a little good news on resolving poor-quality imported electrical goods.
https://www.electrical-contractor.net/ubb/Forum14/HTML/000549.html
