Ragnar,
DONT throw that fridge out yet!!!.
The Klixon that you refer to is a Non-Resettable Over-Temperature device.
Replace it and re-test the fridge.
Just as a passing comment Ragnar, was this fridge plugged straight in after being moved?.
There is a really good chance that the Compressor may have gone, out on overload, through the imbalance of Refrigerant inside the Compressor.
On the Compressor, there should be 3 terminals labelled C, S and R.
Or 1, 2 and 3 respectively.
These are Common, Start and Run, the windings being in Parallel, the difference being that the Current or Voltage-held Relay opens the Start winding, instead of the traditional Centrifugal switch, as in the normal Split Phase motor.
Ragnar, my advice to you would be this:
- Short out the Klixon, or even take it out of circuit.
The worst you can do here is take out the supplying circuit OCP, if the Compressor does not start. - Also short the Thermostat out too and work from there back, if you can't turn the Compressor on and off with the Thermostat, it's faulty.
[This message has been edited by Trumpy (edited 12-06-2003).]
