1 members (Scott35), 381 guests, and 9 robots.
#13941 09/13/02 08:19 PM
Redsy Offline OP
Can you install a 250 volt 3-wire twist-lok plug & receptacle on a 120 volt circuit?
Why, or why not?
#13942 09/13/02 09:00 PM
Well yes it will work but think what will happen when the next guy plugs it into an actual 208 volt circuit. I never recommend doing this.
#13943 09/14/02 07:18 AM
Redsy Offline OP
It was a pool receptacle.
I am curious as to whether the voltage rating is a maximum allowable rating or a strict guideline.
#13944 09/14/02 07:57 AM
If it is not listed for that specific use you can't use it. Also how would you standardize which side is neutral. Can't do it.
