Here's the range of BS1361 fuses found in consumer units:
The traditional fitting had the fuse in a plug-in carrier. These are still available in the Wylex Standard range. You might just be able to see here that the pins on the opened-up 30A carrier are larger than those on the 15/20A unit, thus preventing the insertion of the wrong size fuse:
There are newer types of carrier where the block fitted to the panel has a hinged pull-out. You just pull out the top, drop a fuse into the carrier and push it back in. This is the Hager type:
Also, I never understood why BS1362 (Plug fuses) were never graded making it impossible to overfuse.
To do that there would have to be different types of BS1363 plug, each type designed to accept only the correct size fuse.
Even if this had been done, there would still be the problem of overfusing when somebody chopped the 13A-version plug off an old electric heater to use on their new bedside lamp.
[This message has been edited by pauluk (edited 10-21-2003).]
