One problem is that many of the devices radiate (or transmit back through the wiring) intereference which can be very rich in harmonics -- As you've discovered, the frequencies extend right up into the broadcast range.
It sounds like you might need to install LC filters on some of the system to attenuate the unwanted signals.
