If it can be done safely, you may be able to reverse connections to the primary and secondary windings,
Bjarney, thanks for the suggestion! Why didn't I think of that?
Yes it can be done safely. The top of the tin can can be opened up (it's held by two sheet metal screws) giving access to the sockets and the flex. All I have to do is switch and re-solder the leads to the corresponding points, so it should be fine. Dropping 120 to 115 isn't bad at all...
The regulation on smaller xfmrs is generally not that close.
Paul, I can live with a few extra turns...well...I guess you get what you pay for (US$20) but at least I can open the can it's in.
This is the device in question:
[This message has been edited by SvenNYC (edited 03-11-2003).]
