Page 1 of 4 1 2 3 4
#135870 02/16/03 12:35 AM
Trumpy Offline OP
Paul has started something here,
With respect to experimentation, how many of you people have built something like a Jacob's Ladder or a Tesla Coil, or even a battery made from a lemon or a spud or a
few cups of beer.
This is what got me started in the Trade,
pure Experimentation, do you have a similar story, or do you enjoy just having a go at things such as this?.
It's the simple things in life that matter.
Your input please-
#135871 02/17/03 10:10 PM
Trumpy,
Have setup a few Neon Transformers' High Voltage Secondaries to run a nice fat plasma upwards, across probes made from #12 Steel wire (used with T-Bar Ceilings).
These were 15 KV, 450 VA Transformers.
I have a 9 KV, +/- 300 VA Transformer hiding somewhere. If it comes out of hiding, I'll set it up, get some Digital Shots of the thing pushing a Plasma up the leads, then post the image.
Scott35 S.E.T.
BTW, my friends did not like the time period when I studied things like Capacitance!!!
(AKA... "Hey, grab this silver thing, please!!!" .... "OOOOOWWWWWWWCCCCHHH ,,,, @#%*&@!",,,......)
#135872 02/18/03 12:05 AM
F
now that bring me memories about experments once i did make a "lighting aresster" i use old oil burner transformer and make a instering effect to make it more stronger one i use a GM HEI ingtion coil it do spit out little over 45 kv!! and use that with horn gap and show the lighting effects it look very cool [Linked Image]
merci marc
#135873 02/18/03 01:58 AM
Trumpy Offline OP
Scott,
That sounds pretty cool, I would mind having a look at that one!.
Although, I don't really like the idea of touching the output, when it's turned on. [Linked Image]
[This message has been edited by Trumpy (edited 02-18-2003).]
#135874 02/23/03 01:28 AM
Trumpy Offline OP
Scott,
Have you a list of simple Electrical Projects, for a few young Amateur Radio trainees,I have been asked to teach a class, I've got any Diagrams, could you please give me some help?. [Linked Image] [Linked Image]
[This message has been edited by Trumpy (edited 03-05-2003).]
#135875 02/23/03 01:20 PM
In my trade school the teacher made "Jacob's Ladder" with two of the stools we used to sit on, 3 feet high (1 Meter) tapperd metal stool, he put it on the wood bench and hooked it up to neon a transformer.
It was working great and the class clown starts putting his foot in between the stools then we all saw a perfect arc find a hole in the heel of his boot and at the toe, it was great to watch him jump.
Same class we cooked hot dogs with 2 nails and 208 volts.
#135876 02/27/03 02:00 AM
Trumpy Offline OP
iwire,
That must have been pretty impressive seeing that guy put his foot between the stools! [Linked Image]
I tried that trick, with the sausage and the nails, unfortunately, I used 400V, did'nt work too well, still cleaning sausage-meat off of the walls and ceiling, will try 230V,if there is a next time. [Linked Image]
#135877 03/05/03 02:30 AM
Trumpy Offline OP
Scott35,
Sorry about the mucking around,
what I meant to say was the fact that I have no Circuit Diagrams, we started off with a Crystal Set Radio, and all of the people were asked to build one, next was a 1 transistor amp.
Still working on the next lesson, will be a push-pull amp. [Linked Image]
#135878 03/05/03 10:46 PM
Trumpy,
Let me know what types of circuit schematics you would like, and I'll see what can be done [Linked Image]
Also, here's some images from the high voltage neon transformer (I found it!!!):
Here's some shots of the H.V. Neon Transformer, converted into a "Jacobs Ladder" Plasma producer.
*****Page #1 of 2*****
Fig. 1.1: Transformer with 1" Plasma at the bottom of the "Ladder Wires"
Fig. 1.2: Close-up of 2½ Plasma
Fig. 1.3: Digital Camera wasn't quick enough to catch the Plasma in one place,
so it appears as multiple Plasmas
Fig. 1.4: Another multi Plasma looking image
Fig. 1.5: Fat Plasma at around 3" wide gap.
Scott35 S.E.T.
(P.S. More Images to follow on next page)
#135879 03/05/03 10:48 PM
*****Page# 2 of 2*****
Fig. 2.1:
Fig. 2.2:
Fig. 2.3:
Fig. 2.4:
Fig. 2.5:
-----end.
Scott35 S.E.T.
Posted on 03.05.2003 @ 18:48:00 PST
Page 1 of 4 1 2 3 4
