235
27
Dont let it beat you up Trumpy, The law is the law. We dont make them, just have to follow them. CW
I always knew there was something I liked about those countries where if the majority of people see a law as unfair they just ignore it (officials included in some cases )
I had the same problem with poll tax when it came so i left.
CW
Craig, Where were you living when the Poll Tax come in?. But, how do your work colleagues, feel about this new kick in the guts, regarding RCD's, this is going to change Electrical Contracting, forever, this will be the make or break for the Sole Trader Electrician, just see that I am wrong.(I hope so)
Me was living in the East-End of London, lived there for 5 years on an OE. End of the day Trumpy there are to many contractors around anyway all they do is force the prices down get some them in paid employ and We can start charging a half decent fee for the work we do instead of getting work at any cost. CW
Yes, I agree there Craig. I recently read an interesting article about who should pay for Electrical Safety, the COC system, etc. It paralleled it with the WoF, you have on your car, if you asked the Mechanic to pay for your WoF, the response would probably be not to your liking. People should pay the full cost of thier own safety, after all, it's them that it protects, RCD's, COC's the lot, if they do not like it they should complain to the Regulators, they started it all. Just as a sideline, Craig, did you also know that you are not allowed to use the green wire(even if sleeved), as an additional switch wire, this I think is the most annoying new rule, especially as far as existing installations are concerned. Using this wire, is sometimes, the only option, if you can't run a new wire. I'm puzzled as to the reason for this inclusion.
I think that changed awhile ago we always have run a strap (3 core)i think its a good rule, they seem to be encouraging home owners to bugger with there own wiring. beat me why Have you noticed how a people will mess with there own wiring but not touch there plumbing ? CW
Posts: 1,498 Likes: 1
You mean you used the earth wire as a live wire?
Me was living in the East-End of London, lived there for 5 years on an OE. Which part were you in Craig? I ask because I'm originally from north London myself -- Just curious! Looks like those of us not in NZ need some education on abbreviations again. Trumpy, Appy, could you explain COC and WoF please? As you mentioned the latter relating to cars, I'd guess this is some sort of inspection. (Warrant of Fitness, maybe?) Re using a re-identified green wire, are we to assume that in your equivalent of Romex the earth wire is normally fully insulated to the same degree as the phase and neutral? In British NM-type cable the earth is just a bare conductor within the sheath, although the IEE Regs. do now require it to be sleeved at terminations.
COC = Certificate of Compliance is a wriiten guarantee to the owner/occupier that with prescibed electrical work has been completed in accordance with the current rules,regulations and in accordance with the Act law) completed by the electrician and inspector ( if required ) completed in triplicate, one copy to the owner one to the sparky and one to the board. WOF = yes normally relates to cars but is also relative to electrical work in relation to Caravan's or Connectable Installations they require a electrical Warrant of Fitness every 4 years and can only be done by an Inspector
Yes it was common practice to have a green insulated conductor, sleeved red for a live switch wire on a 2 way circuit and no doubt in house where it is really hard to pull a strap wire (3 core) down a wall it still is.
I lived in Archway, Hackney Wick, Leyton, and Walthamstow while in london and really enjoyed every minute of it, almost stayed there. cheers Craig
