C-H,
Are you sure that all the Swedish dials were the same as British?
I've never come across a genuine old Swedish phone, but I've always been led to believe that zero was at the opposite end of the dial. The NZ dial had zero in the same place as the U.K., but went backwards on all the other digits: i.e. going counter-clockwise:
British/American: 1-2-3-4-5-6-7-8-9-0
Swedish: 0-1-2-3-4-5-6-7-8-9
New Zealand: 9-8-7-6-5-4-3-2-1-0
You can see this reflected in some of the choice of codes. For example, London was assigned STD code 01 as being the shortest to dial. Auckland got 09 as being the quickest on the NZ dial.
I'd always assumed that the Swedish emergency number 90-000 was also assigned at least partly because all those zeros would be fairly quick to dial. (Compare also the NZ emergency code 111, which in terms of dial pulses is exactly the same as the British 999).
Phones here did have letters on the dials years ago. They were used as the exchange prefix in London and some other large cities, and within STD (Subscriber Trunk Dialing) codes. They were phased out by 1970 or thereabouts, after which the letters were dropped from the dials. Evidence of the system can still be seen in area codes and some prefixes today.
The letter assignments differed from those used in America slightly though.
1 (none)
2 ABC
3 DEF
4 GHI
5 JKL
6 MN (UK), MNO (USA)
7 PRS
8 TUV
9 WXY
0 OQ (UK), Operator (USA)
[This message has been edited by pauluk (edited 11-04-2002).]
