On a subsequent point:
I'd be 100% happy with the ring circuit idea if it included that / similar system and changeda few details
1)Face up to the reality that 90% of appliences regardless of their wattage/fusing requirements are fused at 13amps. Given the fact that they're all specified for use with 16amp european outlets this is not a problem.
2)If the UK is going to remain with BS1363 in the long term it could at least introduce fused sockets (at 13amps) that allow the connection of Europlugs (the narrow type only!) as well as BS1363. This would remove the need to jam europlugs into sockets having released the shutters with a screwdriver/pencil etc which does happen quite a lot. It could be designed in such a way as to exclude the larger pinned schuko/french plugs requiring grounding and automatically is incompatable with Italian/Danish/Swiss grounded plugs due to their prodruding pins.
It would prevent any applience from being plugged directly, for any reason, into a 32amp ring. (Poorly designed unfused adaptors, unfused transformer plugs etc etc)
I know it's a comprimise sollution but it would bridge a gap between the UK and European systems much like the Schuko/French design (CEE 7/7)
These sockets could be required on all new installations .. ring or radial. Old sockets simply wouldn't be able to accept Europlugs (unless you force them open.. which already happens)
I would see no reason to change the specificiation for a normal BS1363 plug though. an extra fuse never did anyone any harm
and they're a good design.
On price/practicality.. sockets are expensive once-off investments. Many of them have switches etc in the uk so adding a fuse isn't a huge deal. I've seen flush fitted dimmer light switches in Ireland which have BS 1363 fuses slotted neatly into a fuse carrier the bottom for example. I'm sure a neat sollution for sockets could be developed.. (perhaps a plug in fuse like a car fuse?)
Such a socket would be very useful to the hotel industry for example.
3) For items that require specifically low fusing.. shavers and perhaps some lamps (with old style cords) or anything that needs to be fused at lower ratings: produce moulded on or rewirable plugs (for older fittings) that only accept the correct fuse type.
E.g. a 3amp plug should only accept a 3amp fuse! I'm sure this could be easily achieved.
Most people just jam a 13amp fuse in when a 3amp one blows not realising why its there in the first place. This is the very reason that systems like Diazed/Neozed are designed to make it impossible to overfuse a circuit.
Perhaps non-overfusable version of BS1363 could be developed? BS1363/B ?
As for other safety requirements: read my post in:
https://www.electrical-contractor.net/ubb/Forum9/HTML/000303.html (Re offically proposed RCD requirements in Ireland)
Specifically:
From an ETCI (Electrotechnical Council of Ireland) proposal:
Recommend (to TC2) that all 230/400V electrical circuits be protected by independent RCDs, i.e. sockets protected by one RCD, lights by another
and fixed installations by one or more other RCDs. Smoke detectors and associated emergency lighting should make this proposal easier.
Sound reasonable?
[This message has been edited by djk (edited 05-14-2003).]
