I think it was in 1981 when there were major changes done in our code. Our code is called A.R.E.I. It stands for Algemeen Reglementatie van Electrische Installaties.
That means you were way head of us. BTW. The title sounds like Flemish?
Our code says that you are aloud to use and repair ungrounded sockets from older installations and therefore we can still buy them. It is also written thet it's a breach of the code if you replace a old ungrounded socket with a grounded one without pulling a ground wire.
Same as here, then. What do you do if you add an extra socket in a room with old ungrounded cables?
They are made by Legrand. We use them here when we need to add breakers in a "box" and there's no more space.
Otherwise I don't find them good to work with, since the screws are very small and therefore can cause loose contacts.
Ah. It seemed like the only type Castorama had. I can imagine that they are not as good as ordinary breakers.
>There are special busbars for these models.
They must be pretty small?
>You mean single width 4 pole? No, it doesn't exist yet.
Single width 4 pole? Now, that'll be something! I meant double width 4 pole, but expressed myself poorly. (I doubt anyone could figure out what I meant...)
BTW. The socket you have in your post looks like it has a recessed engagement face? I'm I right? (Ours look just the same!)
[This message has been edited by C-H (edited 10-24-2002).]
