Imperial is just normal English units: feet & inches, pounds & ounces etc.
British Imperial measures have a few differences from U.S. customary units, e.g.:
The Imperial pint is 20 fl. oz. versus the U.S. pint of 16 fl. oz. Our quart and gallon are correspondingly larger.
The cwt is 112 lb. instead of 100, and our ton is therefore 2240 lb. The U.S. ton of 2000 lb. is known as a "short ton."
These are said to be the only examples of something being bigger in Britain than in America!
Those Brits who complain that America corrupted the measurements by changing the size of the gallon are wrong, by the way, because the current U.S. gallon
was used in Britain long before the Imperial gallon was standardized.
Have a look here for more info:
www.wikipedia.com/wiki/Imperial+units The old Imperial-sized cables were designated by number of strands and diameter, e.g. 7/.029 was 7 strands of 0.029" diameter each.
There is a British SWG (Standard Wire Gauge) which was commonly used in radio work. It works in a similar way to AWG with larger numbers for smaller wires, but there's no direct correlation.
Since 1970 house wiring cables have been made to metric specifications, just given as the cross-sectional area in square millimeters (or
millimetres to be British about it!).
For a given size (or its nearest equivalent) the older cables were generally a little larger, but easier to work with. Apart from the stranding and sheath markings, another easy-to-spot tell-tale is that metric cables are just plain copper wires but the older types had tinned strands.
Oh yes... That blue is kind of, er, noticeable, isn't it?
[This message has been edited by pauluk (edited 07-16-2002).]
