by NORCAL - 03/19/24 05:11 PM
0 members (), 260 guests, and 19 robots.
F
Where can I locate a block diagram or simple single line diagram of a basic LAN. ie. Router, hub, telecommunication closet, work station PC, printer etc. I scanned a perfect sketch from EC magazine but must have deleted it. It was ideal to view the basic concept of a structured wiring system.
Thanks,
Frank
Frank;
I can draw up a simple LAN map if you would like.
Scott35
F
Scott-
That would be great! I still use the isolated ground drawings you made and posted several years ago.
Frank
Frank;
I'll draw up something simple and post them in the Technical Reference area.
If time permits, I'll add links to this thread.
Scott35
p.s.
That's great to hear!!! Happy these items are of use to the Members of this Forum!!!
Feel free to use anything else posted here by me also.
(If you use AutoCAD, I can send them to you in .DWG format - mail me for more details).
Scott35
F
Thanks Scott. I'll be looking forward to seeing the drawing in the Technical Reference area. No need for AutoCAD.
Frank (and all other Members);
I finally got the time to draw up a simple and basic LAN map for you.
Check it out in the Technical Reference section, under the topic name of:
Basic LAN Map #1
Let me know if this is what you were looking for, and if I should post other LAN drawings.
Was thinking of including some drawings which show how Peripherals are connected to home based PCs and LAN based Workstations, plus possibly something showing Motherboards + Bus adapters and drives.
Scott35
F
Nice job Scott. It printed out nicely. This is exactly what I was looking for!
Thank you,
Frank
Ron Offline
Nice job.
Is it worth it, to identify the blue connection from the router to the hub/switch be connected to a "uplink" port on the switch, or are you assuming it is autosensing?
Ron
Cool!!! [Linked Image]
Glad you guys like the drawings!
Scott35
