211
Posts: 466 Likes: 1
George,
I had seen the P&S with TOP stamped on the strap. I emailed them, I believe their answer was it didn't matter. So why indicate TOP?
The P&S 20A recepts have top stamped on them, which is ground up. But the 15A recepts do not.
i work maintenance in a factory and i always put them up. because of the metal face plate were to come loose it will not hit the hot line of plug.
I always give the customer a choice and discuss with them the why's and why not's. Most seem to like the ground down. When I put the receptacle sideways I put the neutral side on the top.
Posts: 4,116 Likes: 4
TE, Here's the solution: Bill
Bill, you didn't put your plate screw straight up and down. Go back and fix it please.
I figured diagonal would be best under the circumstances. Bill
I just read the old threads on this topic.
Sorry I reopened this can of worms for you all.
You could just all move to England where this isn't an issue. Probably a bit of drastic solution to avoid the problem though!
hey bill, where can you buy these you posted in your pic? i'll take a 100.
