1 members (Scott35), 520 guests, and 17 robots.
U
Q 1) What is the purpose of ungrounded system. Is it not to trip the circuit breaker when
the first fault occurs? (for more controlled deactivation?)
Q 2) In a grounded system, having one conductor connected to earth provides the reference
for steady voltages supplied to loads. How is stable voltage accomplished in an ungrounded
system?
Q 3) Actually, there is no such thing as an ungrounded system, right? (Because an ungrounded
system is capacitively grounded.. whatever that means)
Thanks for your answers
Sung
Sung,
Welcome to ECN, [Linked Image]
Most Electrical systems throughout the world have a reference to Earth.
This is mainly for Safety reasons.
It is so that there is a limit on the Line to Ground voltage.
pdh Offline
I wouldn't trust an ungrounded system where the primary has a higher voltage than the secondary to be very stable. Impedance grounding is generally adequate for a one fault tolerant system. And you'd need that grounding point to set an alarm to know where there is a fault.
I wouldn't even trust an article 411 system (411.5(A) requiring it to be ungrounded) unless it is isolated with a grounded electrostatic shield between primary and secondary, or has 2 transformers with an intermediate grounded loop at the final secondary voltage.
