The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Live Chat
Join in a Live Electrical Chat!
>> Enter/Register
  Sorry, your browser is not Java enabled, please visit our java support pages in Chatroom
One Doorbell Button to 4 Doorbells/Chimes
by sparkyinak
Yesterday at 11:37 PM
Housekeeping and Clean-up
by renosteinke
Yesterday at 12:52 PM
Back to back bends on electric bender
by Tesla
05/20/12 05:38 PM
Which bright spark can help me here?
by LarryC
05/20/12 11:20 AM
100AMP panel in 60 degree ambient what size wire?
by twh
05/19/12 07:21 AM
An old Amprobe model 550
Shout Box
Top Posters (30 Days)
HotLine1 29
gfretwell 27
sparkyinak 17
twh 15
renosteinke 15
Classified Ads:
Electrical-Classifieds.com
Who's Online
0 registered (), 90 Guests and 2 Spiders online.
Topic Options
Rate This Topic
#129152 - 08/19/04 09:28 AM Shaded Pole Motor Control
TimK Offline
Loc: Witney, Oxfordshire,UK
I need to speed control a 2 pole, shaded pole motor that runs a fan. I have used a simple triac 'light dimmer' control but the harmonic content at low speed settings means there is much vibration in the motor. Any ideas? Is there a simple PWM controller I could use?
Top
#129153 - 08/23/04 03:27 AM Re: Shaded Pole Motor Control
Frank Martino Offline
Loc: Middlebury, CT, USA
Airmaster Fan sells a control manufactured by KB Electronics. It is rated for use with motors.
I assume the difference between the light dimmer and the motor rated unit is added inductance to attenuate the inrush current. The units are cheap enouph to make it worth a try.
Top
#129154 - 08/23/04 04:05 AM Re: Shaded Pole Motor Control
TimK Offline
Many Thanks, I will try them and let you know how I get on.
Top
#129155 - 10/27/04 02:18 PM Re: Shaded Pole Motor Control
arm Offline
Loc: Manchester, NH, USA
what's the difference between a shaded pole motor and a brush type motor ?
[edit: found the answer online elswhere]:
http://www.all-science-fair-projects.com...nchronous_motor
[This message has been edited by arm (edited 10-27-2004).]
Top
#129156 - 10/27/04 03:09 PM Re: Shaded Pole Motor Control
Scott35 Online   happy
Loc: Anaheim, CA. USA
A Shaded Pole Motor is a Brushless type, Single Phase Squirrel Cage Induction Motor, with a Short Circuited "Secondary" (Rotor), and a Shading Pole in the "Primary" (Stator) for Starting.
A Brush type Motor has Brushes contacting a Commutator, which is mounted on a rotatable, wound Armature.
The Commutator segments feed to/from the Windings on the Armature assembly.
There are a few AC Induction Motors with Commutators & Brushes (Syncronous, Repulsion Start, etc.), but for the most part, Induction Motors are Brushless Animals, with the Stator (Primary) Windings Physically Isolated (not connected in a "Physical" way), from the Rotor (Secondary).
The Stator would kind of equate to the Field windings of a Commutator Motor, and the Rotor equates to the Armature of a Commutator Motor.
They work nothing like one another - one functions via Induction, the other Repulsion.
Scott35
_________________________
Top
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
