I can remember back in the early Eighties when protecting electronics started spreading down to the individual dwelling.
- The first line of defense was a good ground, some argued that the isolated ground was the key.
- The next line was to install TVSS.
- Next on the list was load specific isolation transformers with primary to secondary Faraday shielding.
- Then standby power supplies of varying response times, the faster, the more expensive.
- Next came full uninterruptable power supplies.
- Then motor generator sets.
I would add two more steps:
1. Totally local power generation with fiberoptic communication (electrically nonconductive) to the outside world.
2. Place the entire stucture with the generation source in #1 inside a hardened mu-shielded encasement.
I'm not trying to be funny or sarcastic. Just making the list.
Noting that your client is cash limited, one must choose what will give the most bang for the buck.
The isolated ground turns out to be a difficult thing to actually get good results from, so it can be ignored.
I would suggest that the first most effective use of money would be for your client to go to the local computer discount store and to purchase a battery backup standby powersupply for the most valuable computer. I would get this before I got TVSS. Be sure to include any phone or cable connecting to this computer.
Next, get a TVSS outlet strip or plugin block with a lot of equipment insurance. . .the higher the insurance dollar amount and the longer the warranty period, the better the hardware will be.
Next, put in the whole service TVSS.
And if you want to spend more money then start working down the list above.
Al
