I heard a story recently about a bright young college student who was trying to get some sleep in his dorm room, but was unable to because of loud music and partying. In frustration, he grabbed a piece of wire, shorted neutral-to-ground on a plug, and pushed it into the socket, instantly tripping the ground fault sensor on the switchboard and turning the building black. Since it was N-G, no amount of playing with breakers could fix it. The kid unplugged it the next morning, and was never caught.
What an *******!
I have personally tripped the GFP protection of mains (800 amp, 2000 amp) by accidentally causing branch circuit ground faults. It is definitely possible.
That said, I am curious why there was a GFP main tripped by what I have to assume was a 120 volt circuit.
GFP is not required below 250 volts to ground and a 480Y/277 volt GFP device is blind to a ground fault on a SDS.
It is possible to trip a feeder breaker without GFP with a branch circuit short but it is not guaranteed.
I bet he was a EE..... and you don't piss off EE majors for we know how to make and BREAK stuff.
The really smart ones can break stuff without being caught or electrocuted.....
And the really, really smart ones have an even larger stereo to fight back with.... At least, that's our plan for revenge.... and the neighbors are in support of us! The guys playing rap music all the time on Saturday have ticked us off.
twh Offline
Originally Posted by SteveFehr
when backfeeding a portable generator into a 3-prong range/dryer outlet
(ducks)
Can anything good come from that?
Maybe the 208Y/120V Service was GFPE???
I have heard of an installation where there was GFPE on the Service Disconnect of a 208Y/120V 3Ø 4W. system - and it was for Campus Housing (Dorms).
The question was asked to me, if the service required GFPE per the NEC (an Engineering firm had produced the Electrical Plan Set, which was being bid from).
Not having any OSHPD / similar experience, my response was to verify with the CEC (California Electrical Code), along with the AHJ(s), to verify if the service disconnect or Panelboard Feeders required GFPE.
Never heard from that person, which leads me to believe _SOMEONE_ must have required it (or the EE firm is padding the installation for a higher commission).
Other than this possibility, the story sounds like "Bandini Information" to me!
*** "Bandini Information" may be thought of as:
  1. Information having a Male Bovine Fecal Factor, higher than 0.995 - near unity fecal factor,
  2. Information that is typically found in 2-3 cubic foot bags, in the Lawn and Garden section of Home Centers,
  3. Information, which when spread across Lawns, will result in the Grass growing much greener,
  4. Information, that made up the "Bandini Mountain", of which the person was Skiing down in the Bandini Fertilizer Commercial - circa 1970's,
  5. Information having a very offensive odor to it.
Opinions???
Scott
If it's required and you don't have it, it's illegal. If it's not required, but you have it anyhow, that's OK.
IMHO, there are very few situations where ground fault/zero-sequence protection is a bad thing. (Especially considering the wacky hijinks college kids pull.) It's no different than electricians installing $2 receptacles instead of $.39 cent receptacles- the $.39 outlets are all that's legally required, right?
