235
27
Why is sinusoidal supply generated and not another wave shape eg. A square wave
A sine wave is naturally produced as the magnetic field saturates and collapses while the generator rotates.
You get a modified square wave with a 12v-120v inverter because it produces multiple short duration square wave signals and adds them together to approximate a sine wave.
Like Wolfdog says. . .the sinusoid is a map of effects in a conductor cutting magnetic lines of force as the conductor is spun on the perimeter of a drum. An elegantly simple machine.
It is the analog to the square wave's digital.
In the physical world, a square wave that is actually "square" can not exist. The ideal square wave changes states instantaneously. The real square wave ramps from one state to another. . .the better the generator, the quicker the change, but it never happens fast enough to be instantaneous. So the real world square wave is really a highly distorted form of a sine wave, and (this is the interesting part, IMHO) can be created by summing pure sine waves of different amplitude and frequency. That is, a square wave can be thought of as the result of adding a bunch of sine waves together. The square wave may be created by purely mechanical means, and still, there will be high frequency components in it.
Al
Al Hildenbrand
Maybe this sketch will help. Ed
Ed's diagram shows the generation of the sinewave quite effectively. What you have to keep in mind is that as the magnetic field rotates, the rate at which lines of magnetic flux cross the coils is not constant. It is this varying rate of change which results in the sinusoidal wave shape.
As Al mentioned, the sinewave is the purest form of signal. If you inject a pure sinewave into any combination of reactive components (i.e. any circuit which contains capacitance and/or inductance) then you will still get a sinewave at the output. The waveform may be attentuated and phase shifted, but it will still be a sinewave.
Injecting any other sort of waveform into reactive circuit components results in distortion. Trying to send a squarewave down long lines (which have inherent inductance and capacitance) results in a very distorted waveform at the distant end. That's because the higher-frequency components of the waveform are affected differently to the lower ones, thus upsetting the balance which produces the original squarewave.
Posts: 2,723 Likes: 1
Broom Pusher and Member
Great information posted by everyone here! Also, great drawing by Ed!
Just to sum things up, a Rotating Generating device (such as Alternators) will produce "Somewhat Sinusodal" AC output (not going into details regarding any internal things within the generating device which might either distort or alter the wave format).
Now what the AC looks like after connecting various loads to the generating device, is going to result in anything but a nice looking Sine Wave!!!
Harmonic Distortion will turn that neat and uniform wave into something with jagged spikes, sharp peaks and a bunch of multi frequency pulsations within the overall envelope!
The output of some DC/AC Inverters will be morelike something between a plain-old square wave and a "Saw-Tooth" wave - depending on how the power amp Transistors are driven.
Scott s.e.t.
