466
11
OK, here's a trivia question. Why do male attachment plug prongs (some, not all) have round holes through them near the ends??? I DON'T know the answer!!
Helps hold the plug into the receptacle. There is a corresponding "dimple" in the contact spring, which "locks" into the hole in the plug blade.
Posts: 2,236 Likes: 1
And here I thought they were to clean the contacts...?
Makes sense though...
Don't forget that the holes also make it easy to wrap bare wires for Mexican-style extension cords....
Interesting comments but: The holes have been there a LONG time... long before lockout/tagout came on the scene, however I have seen some loto devices that use the holes. The contact idea is interesting but I've never seen a receptacle with contact strips having dimples... A cleaning function is interesting...could be! Still searching!
Anonymous
Unregistered
I was told back in school that a long time ago receptacles had little spring loaded balls that would engage those holes.
My bet is that they are part of the manufacturing process, like maybe how they are hung onto when they mold the plug around them. Trainwire
I've got a 1970ies Sony stereo with NEMA plug and an unswitched outlet. When I push in a plug I can feel that the prongs get locked when fully inserted. BTW, I was close to using the mexican style cord. I replaced a light switch in a room without a window, so I needed some temporary lighting. The only thing I could find was an imported US table lamp with an adaptor which has been hooked up forever in our living room. When I tried to hook it up I nearly got a fit. The adaptor was as stone aged as the lamp and it wouldn't fit Schuko receptacles! Finally I pulled two (illegal) ungrounded extension cords through the appartment and hooked my lamp up. SO much about being able to stick to codes...
Don't forget that the holes also make it easy to wrap bare wires for Mexican-style extension cords.... I'm not an old timer on this site but I bet there are some pics of this in the violation photo forum. I've seen that practice done plenty of times, unfortunately. Luke
Luke Clarke Electrical Planner for TVA.
