1 members (Scott35), 513 guests, and 40 robots.
#127877 02/27/02 06:09 PM
F
Is 2.0 watts per cubic foot a good general formula to calculate for baseboard heat. eg. If a room is 15ft x 15ft 8ft ceiling would one 2000 watt baseboard heater be sufficient? It has been working well for me. I was curious if anybody else used it. I believe I saw the formula in a magazine many years ago.
#127878 02/27/02 08:42 PM
I use 1000w in a room that size in Oklahoma.
You need to do accurate heat loss calculations to determine how much heat you need. Too much heat is often better than too little.
#127879 02/27/02 10:45 PM
I use 8-12 watts/sq.ft. depending on insulation levels.
#127880 02/28/02 11:52 AM
JBD Offline
I've always used 10 watts/sq ft.
It really depends on your area of the country.
#127881 03/01/02 08:09 PM
F
I spoke to a HVAC Supervisor today at work. I didn't think to do that before my original post. He looked in his engineering book. He told me the formula for electric baseboard heat is: 2.03 watts per cubic foot. (Pennsylvania) Thank you for your respective inputs.
