1 members (Scott35), 216 guests, and 11 robots.
#127435 07/11/01 05:21 PM
habbbby Offline OP
Is there a schematic here somewhere of a flor. ballast, two lamp. Two red, two blue and two yellow, with of course the feed. Iam curious as to how the coils are layed out internally.
#127436 07/11/01 05:37 PM
Anonymous
Unregistered
Not yet, but four days ago Scott wrote: "I'll post some Ballast drawings ASAP...", so stay tuned.
#127437 07/12/01 01:05 AM
habbbby,
Sounds like you are describing a Rapid Start - Hot Cathode Ballast for 2 lamps - typical of F40T12 lamps and HO/VHO lamps of 4' and 8' length.
Unless something changes between tonight and Friday, I will have a whole weekend off!!! Ya, Baby!.
Plan to post a few Audio Xover [passive] schematics, a couple simple motor drawings, and whatever I can draw/convert/post. I'll add a couple Ballast drawings - especially the RS hot Cathode Ballast you are asking about.
Your request is granted [Linked Image]
Scott SET
#127438 07/12/01 05:45 AM
cool!
#127439 07/12/01 10:26 PM
habbbby Offline OP
yes that is the specific type I was asking about. Thanks, I will be looking for it!
#127440 07/16/01 12:32 AM
Well, the Monkey wrench of time got thrown into the cogs of my "so-called" weekend off [Linked Image]
Instead of getting things done like previously planned, only had Sunday off [thankfully [Linked Image]] - which gave me enough time to get 25% [1/4] of things done [Linked Image]
Nevertheless, I have posted the Ballast Schematic in the new Technical Reference area, which habbbby was inquiring to.
It's under the subject F40 T12 2 lamp Ballast schematic type 1
I hope it's to your liking!!!
P.S. check out the speaker crossover schematics posted there too..
Scott SET
#127441 07/20/01 03:00 AM
can the function of the 'heater' winding be explained?
#127442 07/20/01 04:29 PM
Anonymous
Unregistered
It is a property of most materials that they will give up electrons much more easily when hot - meaning temperature. This was common nuisance with tube devices that had to be turned on to warm up for several minutes before they would begin working.
Cold cathodes typically employ a much higher discharge voltage so they can emit adequate electrons at typical room temperatures. Alas, this is much less efficient.
Hot cathodes have a heater (basically a little tungsten filament with a special coating) that emits lots of electrons to travel through the gas in the tube and make it glow.
Hot cathodes are quite a bit more efficient. About the only advantage of a cold cathode is the instant start..
#127443 07/21/01 03:04 AM
thanks...
would this explain HO's ?
#127444 08/30/01 10:24 PM
Anonymous
Unregistered
I just noticed your question. What is it that you wanted explained?
